Has anyone installed in spring air bags to by pass leaky air shocks?
Results 1 to 7 of 7
Suspension, Brakes and Tires Discussion, Has anyone installed in spring air bags to by pass leaky air shocks? in Item Specific Cadillac Discussion; I see these Airlift kits $75 to $100. Has anyone converted the leaky air shocks by installing "in spring" Airlift ...
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Has anyone installed "in spring" air bags to by-pass leaky air shocks?
    Has anyone converted the leaky air shocks by installing "in spring" Airlift bags connected to the OEM air pump?
    This seems like the better cost effective way out of replacing the entire insanely priced road sensing shocks.
    Its essentially doing the same thing in a much simpler way.
    http://www.strutmasters.com/Riviera-...l-60776-br.htm
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Has anyone installed in spring air bags to by pass leaky air shocks?
    Does this concept not compute in this very dead section of the forums?
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,191
    Re: Has anyone installed "in spring" air bags to by-pass leaky air shocks?
    johnny k, The AirLift bunch has been around since at least 1960 or so. Used their excellent stuff in a '65 Chevelle SS and a '65 Pontiac LeMans. Before I would ever go to passive rear shocks in the car in order to "repair" a faulty ELC system I'd go to a pair of their manual bags and keep the active controlled shocks.
    One could then set the bags at a tad over normal ride height and no amount of rear load would compress the springs.................
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    They've been around since the 40s.
    Oct 2009
    Pigseye, Mn
    56
    2,814
    This suspension forum is still alive! I'm getting weak pulse.
    I am well aware of them being around for the last 60 years.
    The question is-
    Has anyone considered this as an alternative to replacing active shocks with a leaky bladder? The pro's & con"s?
    Leaving the active shock in place & tieing the airlift bags into the ELC system.
    They operate in a 5 to 35psi range, it would then pump until the car reaches its specified
    height & maintain that level being controlled by the wheel position sensors.
    I have read the OEM air bladders operate normally at about 15psi. This kit actually fits 85 to 93 E body Sevlle, Eldo, Deville,Fleetwood also many model of Buick Olds ford/merc 1985-2006
    http://www.jegs.com/i/Air-Lift/022/6...oductId=743887
    94CaddyConcours's Avatar
    94CaddyConcours is offline Cadillac Owners Fanatic
    Automobile(s): 1994 CADILLAC DEVILLE CONCOURS, 350ZR
    Jul 2004
    LONG BEACH KALIFORNIA, HOUSTON
    444
    Did you ever got around into installing it?
  10. Remove Advertisements
