1995 SLS Steering problem
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, 1995 SLS Steering problem in Item Specific Cadillac Discussion; I was looking into buying a '95 SLS with 142,000 miles on it. While test driving I noticed the power ...
    _silentmike_ is offline Cadillac Owners Member
    Aug 2003
    I was looking into buying a '95 SLS with 142,000 miles on it. While test driving I noticed the power steering not working while stopped and while at a very slow speed as in coming to a stop. This happened in gear and in park, at idle and while giving the gas. It has plenty of P/S fluid and the pump is not seized. It did not happen all the time.
    I recall when I worked in a Cadillac/Oldsmoble dealership as a Tech. in the late 80's that we did alot of replacements of steering racks due to the seals inside getting hard and causing a similar problem. As I have been out of the business for many years I am not up to speed as to whether this is the same problem. Any help would be much appreciated. Thank You, _silentMike_
    kcnewell is offline Cadillac Owners Connoisseur
    Jan 2003
    Nevada, Still the land of the free!
    2,235
    Re: 1995 SLS Steering problem
    It could be the rack, but I wouldn't go into that untill I checked the pump ( a lot less trouble ) It could cause the same symptoms.
