Delphi Delco ABS pump leaks
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Delphi Delco ABS pump leaks in Item Specific Cadillac Discussion; 2004 Deville, The ABS pump / valve block leaks. NOT the module. Where can I get a repair kit or ...
    RMT Customs is offline Cadillac Owners Member
    May 2011
    1
    2004 Deville,
    The ABS pump / valve block leaks. NOT the module. Where can I get a repair kit or get this repaired? New from GM over $800.00. Bought a salvage and it leaks at the same place.
    Thanks
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Delphi Delco ABS pump leaks
    I hear the components of this compressor are not available. Somebody is making them.
    Arnott sells refurbished units. There must be others, Strutmasters, Suncore, I have looked for a parts sources but its too difficult tracking down who is supplying what for these systems.
