rear caliper problem..HELP!
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, rear caliper problem..HELP! in Item Specific Cadillac Discussion; I cant get the piston to retract, what is the problem bleeders open... c clamp pushing inward ..need help..qualityfabrications@gmail.com...
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    63
    161
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: rear caliper problem..HELP!
    The piston needs to rotate in or you may damage it. If you were to open the bleeder it may rotate in easier.
    This is because the mechanical brake function in the rear.
    The piston face has a spanner tool provision but can be rotated in carefully with some
    needle nose pliers or a inexpensive universal tool that looks like this.
    Not using the proper tool you stand the risk of tearing the boot seal.
