Does anyone know which side of master cylinder goes to which wheels... 00 Deville
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, Does anyone know which side of master cylinder goes to which wheels... 00 Deville in Item Specific Cadillac Discussion; I am trying to find out if my rear brakes are plumbed correctly. My understanding is the Lt front and ...
    jimsbox is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DHS
    Apr 2005
    Kansas City
    63
    544
    I am trying to find out if my rear brakes are plumbed correctly. My understanding is the Lt front and Rt rear should both come off the front half of the master cylinder and the Rt front and Lt rear off the back half of the master cylinder is this correct. I gravity bled my Rt rear until the fluid dropped lower (in the front half of the reservoir). I believe it is correct but there is some question that the rear lines may be crossed.
    johnny kannapo's Avatar
    johnny kannapo is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Eldorado
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Re: Does anyone know which side of master cylinder goes to which wheels... 00 Deville
    The primary master cyl. piston is closest to the firewall the secondary piston being stacked if front of it pointing forward.
    If you have 4 lines at the master cyl. you have a diagonal circuit -one front & the opposite rear one circuit. The other lines being its opposite. Many FWD's have this diagonal configuration.
    I believe our caddy's have a front/rear split traditional system at the master cyl. found on most rear wheel drive cars. The frt & rear supply pressure to the EBCM that distributes a proportioned supply to the individual wheel brakes as many other inputs are processed by the various chassis controlers. There is a lot going on in time span of milliseconds.
    This brake system is everything but traditional.
    Oct 2009
    Pigseye, Mn
    56
    2,814
    Allow me to correct myself... This is a diagonal system the forward port suppling the RT. front & LF rear and the rear port suppling the LF front & RT. rear calipers.
    This link has a the complete brake circuit. -Page 215
    http://www.cadillacforums.com/cadillac-suspension.pdf
    Apr 2005
    Kansas City
    63
    544
    Thanks Johnny, that is what I was afraid of, when I bled the right rear, the front reservoir was the one that was draining so the lines are not hooked up correctly. Guess I will have to switch them this weekend.
    Take care.
    Jim
  7. Remove Advertisements
