pulling trans
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, pulling trans in Item Specific Cadillac Discussion; never seen a trans dropped out the bottom on a newer GM FWD car. in most cases the subframe is ...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    pulling trans
    never seen a trans dropped out the bottom on a newer GM FWD car. in most cases the subframe is lowered. than trans is separated from motor? so motor is supported from above? does motor have to be lowered a bit to pull trans bellhousing away from motor?
    Aug 2007
    mpls mn
    2,527
    Re: pulling trans
    checked alldata today. trans removal procedure is about what i thought. support motor. remove subframe. pull trans.
