Need Help with two issues.. Rear shock replacement and front wheel hub assy's
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Need Help with two issues.. Rear shock replacement and front wheel hub assy's in Item Specific Cadillac Discussion; I am tackling these two issues this weekend. Can anyone help me with write ups on how to do these ...
    bowanna03 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Jul 2010
    40
    23
    I am tackling these two issues this weekend. Can anyone help me with write ups on how to do these and tips? Does anyone have reccomendations for affordable and good parts? Which shocks should I go with and what Wheel hub assys. I am assuming I shouldn't cheap out on the wheel hub assys and I should try to find an affordable option instead of the air shocks? Any help would be appreciated. While I am doing all this should I do anything else that can be replaced. Thanks guys
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Re: Need Help with two issues.. Rear shock replacement and front wheel hub assy's
    ever done a FWD hub before? if you have, than no point in offering advice. if not, than make sure you have proper tools. large 34mm socket? hub is almost always rusted too knuckle. and splined axle shaft seizes in hub. a puller helps to force axle out. any brand hub is ok. aftermarket may not last as long as name brand but most come with warranty.
