sts front strut noise
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, sts front strut noise in Item Specific Cadillac Discussion; I have a 2000 STS with 54,000 miles and I am experiencing noise from the front springs when I go ...
    kgwatkins is offline Cadillac Owners Member
    Automobile(s): 2000 STS
    Jan 2011
    71
    3
    I have a 2000 STS with 54,000 miles and I am experiencing noise from the front springs when I go over speed bumps and severe dips on the highway.
    Is there any way to lubricate the Mcphearson struts?
    Is there any other solution short of replacing the struts?
    Thanking you in advance.
    kgwatkins
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Re: sts front strut noise
    car is not bottoming out? probably not. describe noise. clunk or rattle? could be strut mounts. on top of struts. or sway bar links or sway bar bushings. you cannot lube struts to make them quiet. might be any number of suspension parts. ball joints, tierods, strut rod bushings. even loose or mushy rack bushings. do tires have even wear? no funny edge wear? could even be bad wheel bearings.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,590
    My money is on the sway bar bushings or connector links.
    Jan 2011
    71
    3
    Thanks for your reply.
    Sounds like the spring is rubbing or moving in the spring seat. The noise is most dectable when going over a speed bump slowly. The sound is like a skrunch wnen the wheels are driven up and again when going back down.
    thanks
  7. Remove Advertisements
