using resistor to fool computer
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, using resistor to fool computer in Item Specific Cadillac Discussion; 96sts. put in resistor on 1 front shock. no more codes. is shock default to soft or firm or what ...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    96sts. put in resistor on 1 front shock. no more codes. is shock default to soft or firm or what now? will i notice a difference in ride on rough roads from left/right side of car? i don't see any difference. should i put a resistor on both sides to make struts react the same?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    Re: using resistor to fool computer
    Your STS has active suspension control for the front struts and rear shocks. If you defeat one side you MUST do the other. Default is soft - there's no longer any valve restriction control so the fluid flow is wide open. The front end will now handle like an SLS, not an STS, and the struts will NOT "react": they're now passive.
    Aug 2007
    mpls mn
    2,528
    yes, sub i know shock is passive. so 1 shock is soft and 3 are firm at speed? define firm after 125k miles/15yrs? new struts would be great but $2k is pretty steep for a slight improvement in handling. has anyone on this board ever changed all 4 struts with OEM stuff on a 95-97 vintage car?
    Feb 2006
    56,582
    Quote Originally Posted by stoveguyy View Post
    (1 strut/shock is passive and 3 are controlled at speed. Depending on road conditions the changes from soft to firm are constant and infinite.)
    define firm after 125k miles/15yrs? (That's anybody's guess)
    (Unknown, but that is the ONLY way to retain the original handling control as designed.)
    cl8525 is offline Cadillac Owners Member
    Automobile(s): 99 black on black STS
    Sep 2010
    18
    What type of resisters were used. I need to do the same on a 99 sts. Can you post a pic of the resisters and how you installed them also a part #
    Feb 2006
    56,582
    The resistors are 1/2 Watt carbon types - $1 a 5-pack at Radio Shack. Look for JimD's posts on the subject. You simply jumper the connector with a resistor. 4.5 KOhm, I think. Insulate and waterproof well.
  9. Remove Advertisements
