1988 Fleetwood Automatic Suspenison Trouble
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, 1988 Fleetwood Automatic Suspenison Trouble in Item Specific Cadillac Discussion; I am new to this forum, but it looks like alot of smart people here. I have a 1988 Fleetwood ...
    hooty is offline Cadillac Owners Member
    Aug 2003
    North Alabama
    Unhappy1988 Fleetwood Automatic Suspenison Trouble
    I have a 1988 Fleetwood d'Elegance (FWD) and am having trouble with the automatic suspension. The car, as long as I have had it - 2 years, sits low in the back. The air compressor does operate, but still sits low. I replaced the drivers side rear strut the other day thinking that it wasn't working right. The car still sits low. I disconnected the sensor arm yesterday and made it go up and down so I know that the struts are rising, but when hooked up normally it still leans down toward the back. You reckon the springs are shot and the struts can only do too much???
    Thanks
    Mark
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    Re: 1988 Fleetwood Automatic Suspenison Trouble
    You got the idea alright. The springs are supposed to set the car at proper trim height when the car is unloaded (standard curb weight). But when you add weight to the rear of the car, the air shocks (or struts) on Cadillac cars are only supposed to compensate for the added weight. They are NOT intended to make up for sagging coil springs.
