cold suspension rattle
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, cold suspension rattle in Item Specific Cadillac Discussion; 96 sts. i get a rattle from front suspension only when cold. feels like a rattle that could be from ...
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    96 sts. i get a rattle from front suspension only when cold. feels like a rattle that could be from the sway bar links or maybe swaybar bushings? did replace an inner and outer tie rod on both sides recently. only notice it for first several miles. can go to store. stop and than coming home there is no noise. are there any suspension bits that can quiet down as the car is driven? how about a worn CV joint? do they make noise when cold and quiet down as the car is driven?
    spencerk73 is offline Cadillac Owners Member
    Automobile(s): 1994 Eldorado
    Feb 2011
    14
    Re: cold suspension rattle
    I'd try to get under the car (while it's off) and grab different components and see if one has excessive play in it. Just a quick way to check for anything obvious. BTW things do expand when they get warm
    Aug 2007
    mpls mn
    2,528
    the strut bellows inside spring is clamped at top but loose at bottom. the spring seat has lots of snow/ice that melts and than builds up so it could come and go. sound is worse below 15F? bellow is pretty stiff plastic. i think bellow should be extended and clamped at bottom to keep strut clean?
    Rusty058's Avatar
    Rusty058 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS LuxII
    May 2010
    Milford, Connecticut.
    58
    141
    Quote Originally Posted by stoveguyy View Post
    I had the exact same symptoms you describe on my DTS.I have an appointment next week to have a strut mount replaced
    Aug 2007
    mpls mn
    2,528
    replacing the strut mount is a bit of work. probably need to check alignment on my car. a 06 probably not. i put new struts/mounts in my grand prix last summer. fun job.
  8. Remove Advertisements
