Buying new rotors/pads - advice
Results 1 to 8 of 8
Suspension, Brakes and Tires Discussion, Buying new rotors/pads - advice in Item Specific Cadillac Discussion; Next Friday, I will be replacing my rotors and pads. I am unsure whether to get ceramic, or semi-metallic pads. ...
    Skiller.'s Avatar
    Skiller. is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Next Friday, I will be replacing my rotors and pads. I am unsure whether to get ceramic, or semi-metallic pads. I've heard that you need rotors capable of handling the ceramic pads. Is that true?
    I don't want to spend a fortune on the sport EBC rotors (although they are nice), but I also want GOOD quality parts.
    I like the idea of ceramic pads because they produce less dust, but I don't want to get ceramic pads with the wrong rotors. I will also be using the pad wear sensors.
    I've heard too many things about various rotors. Which rotors??
    What would be my best option?
    RockAuto has Monroe semi-metallic pads w/ wear sensors for a great price, along with a rebate. Would you use Monroe pads?
    Thanks!
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Re: Buying new rotors/pads - advice
    Also, do I have to bleed the brakes when I am finished??
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,197
    Quote Originally Posted by Skiller. View Post
    Just the opposite - if your brake fluid reservoir is now full you'll have to remove some fluid before you start: the simple act of pressing in the front pucks and screwing in the rear pucks will return fluid TO the reservoir and it will overflow - keep an eye on fluid level each time you finish a wheel.
    You never break into the sealed fluid system while changing rotors and pads - the manual tells you how to hang the caliper up on the suspension without unduly bending or disconnecting the brake line.
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Thanks Jim! How do you remove fluid? Siphon??
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    I'm leaning towards Raybestos Advanced Technology rotors and ACDelco Durastop ceramic pads...
    Would be about $330 shipped for all 4 wheels.
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Quote Originally Posted by submariner409 View Post
    Also, does the fluid that I siphon out go back in once I finish installing the new pads??
    rtalipski's Avatar
    rtalipski is offline Cadillac Owners Member
    Automobile(s): 2001 Seville SLS
    Feb 2005
    Northeast PA
    23
    I personally have never touched fluid levels during a brake pad replacement (they never fluctuated enough) but when I look up manual it does say...
    # Inspect the fluid level in the brake master cylinder reservoir.
    # If the brake fluid level is midway between the maximum-full point and the minimum allowable level, no brake fluid needs to be removed from the reservoir before proceeding.
    # If the brake fluid level is higher than midway between the maximum-full point and the minimum allowable level, remove brake fluid to the midway point before proceeding.
    so I would say if you needed to siphon any out you probably won't need it.
    Just check your reservoir level when your done.
    Also just pickup a turkey baster from the dollar store... and just remember not to use it on turkey day... lol
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Yeah, that's what alldata says as well.
    Considering that these pads I'm replacing are fairly new (I'm replacing because they suck), I don't think the pistons have to be pushed back into the caliper much. I might not even have to touch the fluid level, but I will monitor.
    Thanks!
  11. Remove Advertisements
