1973 DeVille Upper Ball joint replacement
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 1973 DeVille Upper Ball joint replacement in Item Specific Cadillac Discussion; Anyone have any info on replacement of an upper ball joint? The manual I have says the ball joint is ...
    milehighassassin is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    Vail/Fort Collins, CO
    37
    13
    Question1973 DeVille Upper Ball joint replacement
    Anyone have any info on replacement of an upper ball joint? The manual I have says the ball joint is welded in so if it needs replaced the entire control arm must be replaced. It does appear to be welded in. any info or tips on how to deal with this? I can't locate a new upper control arm. Everyone seems to sell an upper ball joint, pricey but they sell them.
    TIA
    D-Short is offline Cadillac Owners Member
    Automobile(s): 1971 Sedan Deville
    Jun 2009
    45
    4
    Re: 1973 DeVille Upper Ball joint replacement
    I replaced mine with Moog, they are welded in, but its more like two good tact welds.
    Nov 2007
    37
    13
    So does the new one need to be welded in as well, or does it bolt in, press in?
    Thanks!
