1998 Deville: go with Arnott, Suncore, Monroe air ride shock?
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, 1998 Deville: go with Arnott, Suncore, Monroe air ride shock? in Item Specific Cadillac Discussion; My left rear shock leaks a little. Compressor cycles fine and both shocks pump up (trunk test), but as soon ...
    jpix is offline Cadillac Owners Member
    Automobile(s): deville
    Dec 2008
    52
    58
    My left rear shock leaks a little. Compressor cycles fine and both shocks pump up (trunk test), but as soon as the cycle stops a small hissing sound from left strut 4 minutes compressor kicks on. Soooo
    I'm going to replace with either Arnott, Suncore, or Monroe. I can get Monroe from Advance Auto slightly less $$ than Arnott. Suncore is about $40 less than Arnott. With money not an option, What system would you go with?
    I lean to Monroe, only because of the big long lasting name. Input? , But like the total setup of Arnott.
    Reliability?
    85silvereldo is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    36
    Re: 1998 Deville: go with Arnott, Suncore, Monroe air ride shock?
    what is the trunk test you are referring to??????????
    Dec 2008
    52
    58
    With trunk door open, setting on the edge and alowing the compressor to kick in to level the rear end. It does that and a small hissing sound from the drivers side wheel well. Ordered Arnott's today. I'll get back when I have time to install in a few weeks....
    Mistake on the Monroe's from Advance Auto, they are OEM and $430 each..... couldn't see spending $860..
    Dec 2008
    52
    58
    Update. The Arnott air will work fine. My '98 Deville doesn't have the eletronic solanoid on each shock.
  7. Remove Advertisements
