Best Brake Caliper Anti-Seize/Grease Compound?
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, Best Brake Caliper Anti-Seize/Grease Compound? in Item Specific Cadillac Discussion; I'm looking for advise as far as what is the best grease to use on caliper slide pins. I've heard ...
    Pete1996 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS, 1996 STS - RIP
    Aug 2009
    CT - USA
    198
    I'm looking for advise as far as what is the best grease to use on caliper slide pins. I've heard good things about SIL-GLIDE and Permatex Anti-Seize Lube. I'm interested in the expert's experience as far as which or any other performs the best.
    Thanks in advance!
    Aug 2009
    CT - USA
    198
    Re: Best Brake Caliper Anti-Seize/Grease Compound?
    Also hearing good things about CRC Sta-Lube ... opinions?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    I like Permatex products for no particular reason. Caliper pin lube all comes out of the same synthetic pipe. I have also used good ol' lead-copper-tin-grease based anti-seize.
    Aug 2009
    CT - USA
    198
    Quote Originally Posted by submariner409 View Post
    I also like Permatex products, but I'm not sure what you mean by this as I've been finding all sorts of different compounds. SIL-GLYDE is a white silicone grease with no metal added as far as I can tell whereas the Permatex is a petroleum based product with aluminum and graphite added:
    http://www.permatex.com/products/Aut...ubricant_a.htm
    http://www.permatex.com/documents/ms...lish/80078.pdf
    Info on Sta-Lube it has moly, zinc, and graphite compounds in it:
    http://www.crcindustries.com/auto/co...?PN=SL3303&S=N
    MSDS:
    http://www.crcindustries.com/faxdocs/msds/4069.pdf
    I have heard that many OEMs use this Never Seez material that is copper and aluminum based:
    http://www.neverseezproducts.com/ant...m#RegularGrade
    Aug 2009
    CT - USA
    198
    This seems to be a better Permatex product, claims to be synthetic but not silicone based but they don't tell what it actually is. MSDS claims that it is a trade secret, LOL! No mention of any metals included:
    http://www.permatex.com/products/Aut...per_Lube_1.htm
    I tend to avoid materials where I have no idea what is in them, unless there are reliable reports of superior performance.
  8. Remove Advertisements
