Hub cap lock removal?
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, Hub cap lock removal? in Item Specific Cadillac Discussion; I just discovered two McGard-style hubcap locks on each wire wheel cover on my just-acquired 1978 Seville Roadster! I did ...
    unpolire is offline Cadillac Owners Member
    Automobile(s): 5, so far, 2 convts.
    Jul 2008
    California
    21
    I just discovered two McGard-style hubcap locks on each wire wheel cover on my just-acquired 1978 Seville Roadster! I did not find an unlocking tool with the car, so now I'm stuck! Any ideas? I don't see how it will be possible to identify which number lock set I have to obtain an unlocking tool, as these look original from 1978. Cut them off?
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Re: Hub cap lock removal?
    This style lock, 2 on each hub cap is factory original. Behind the cap an L shaped lever turned into a recess in the steel wheel. The locks are turned about a half turn to move this L shaped lever free from the rim. Without a wrench, you can drill a hole in the head of each lock and use a broken screw tap tool that grips in the hole as its turned counter clockwise.
    Jul 2008
    California
    21
    Thanks for the learned response. Nice to know they are original. Too bad that I cannot save them!
