20 inch rims do i need a spacer
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 20 inch rims do i need a spacer in Item Specific Cadillac Discussion; I was wondering i have been to a shop that has doen a regulare balance on the wheels 2 times ...
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    I was wondering i have been to a shop that has doen a regulare balance on the wheels 2 times and it will not take out the shimmy they say that the balane zeros out each time so im betting that maybe its the balance and i need to get a hunter RFB balance wich im gona go for tomorrow
    but also will they tell me that i need a spacer ? someone told me that sometimes on aftermarket rims you need a spacer do are cars require them
    also fi the tire is good and the wheel is not bent and the the shop tells me the shake is normal shimmy that is BS right ?
    does anyone els have trouble after putting 20s or anyting aftermarket on there seville 1998 to 2002 ?
    Qball Customs is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Dec 2008
    42
    52
    Re: 20 inch rims do i need a spacer
    I had the same issues until I went to a high end wheel shop and they sold me some hub spacers, all the shake and shimy disappeared.
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    in your case it sounds like you bought the wrong offset rim and the spacer made it the correct offset.
