93 deville brake caliper sticking
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, 93 deville brake caliper sticking in Item Specific Cadillac Discussion; hey everyone just found out today why my car has no power and is only getting 10mpg my right front ...
    mike93 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Cadillac sedan deville
    Sep 2009
    Media, Pennsylvania
    25
    281
    hey everyone just found out today why my car has no power and is only getting 10mpg my right front brake caliper is sticking the car is pulling to the right and burning smell is coming from that side it's not safe to drive like that right??
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    Re: 93 deville brake caliper sticking
    Of course not. The heat will pop the tire, ruin the wheel bearing, melt brake parts, bushings, etc etc. That wheel will slide in turns and in the rain. Totally not safe.
    Feb 2003
    california
    69
    6,663
    Probably needs new caliper guide pins both sides and properly lubed when replaced. If they are lubed and the caliper slides freely, and it still hangs up, I would suspect the rubber hose to the caliper. If you jack up the car and that wheel is hard to rotate, crack open the bleeder screw and if now it spins free, that confirms a failed brake hose. If the hose is the problem replace both front hoses and flush the brake system. DO NOT DRIVE TILL FIXED!!!
    Feb 2003
    california
    69
    6,663
    You might check the age of this post! He's either been killed by this car or had it repaired already! The problem with forums is the original poster rarely posts back to tell us its fixed so others can benefit
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by carnut View Post
    ....The problem with forums is the original poster rarely posts back to tell us its fixed so others can benefit
    Well said! !
    The world is populated by more takers than givers.
  8. Remove Advertisements
