Need advice please - Sway bars deville 2003
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Need advice please - Sway bars deville 2003 in Item Specific Cadillac Discussion; I have a 2003 Deville that rides well except for excessive body roll. The sway bar links were recently replaced ...
    dangodek is offline Cadillac Owners Member
    Automobile(s): Deville 2003
    Sep 2009
    Michigan
    1
    UnhappyNeed advice please - Sway bars deville 2003
    I have a 2003 Deville that rides well except for excessive body roll. The sway bar links were recently replaced with blue poly and got some improvement. Is the diameter of the bar on a DTS thicker than base deville? If so, would like to find some. Eibach only makes thick sway bars for CTS and Escalade but no deville.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,534
    Re: Need advice please - Sway bars deville 2003
    Like the STS, the DTS has slightly larger diameter sway bars, so a junkyard crawl for the bars, links AND the brackets should produce results.
