GRRRRR Brake job problems
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, GRRRRR Brake job problems in Item Specific Cadillac Discussion; So I went to replace the brakes with 2 new front calipers, and all new rotors all around. Here is ...
    bigds01 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Seville SLS
    Nov 2009
    137
    So I went to replace the brakes with 2 new front calipers, and all new rotors all around. Here is the end result, I broke the bleeder screw on the brand new drivers side front caliper. When taking off one of the bolts of the rear caliper it was so rusted in snapped in half.
    So now my question: I clearly have a ton of air in the lines now, what is the easiest way to drain and bleed the entire system? I want to put in DOT4 fluid.
    also
    Does the rear piston that you have to screw in to get the caliper back on pop out when you engage the brakes with the car on?
    79devillescott is offline Cadillac Owners Member
    Automobile(s): 1979 Cadillac Coupe Deville
    Oct 2015
    32
    12
    Hey man did you get any advice on your question or what did you do to figure it out if you did because I am having the same exact issues with my car so many times I went through six bottles a break fluid air still keeps coming out
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,632
    Quote Originally Posted by 79devillescott View Post
    If you have air coming out you have a leak somewhere... What exactly did you change, if calipers did you use new copper washers on the hoses?
    Oct 2015
    32
    12
    I change my brake master cylinder, my proportioning valve because I thought they may have air in it when I was bleeding it big hard clumps of rust started coming out and some ibreak lines that were rusted and broke when I removed the proportioning valve I have looked everywhere and could not find a leak
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: GRRRRR Brake job problems
    You're asking a question of a member who has not logged in for over 6 years - the date of his question is 12-29-09.
    Oct 2015
    32
    12
    I got one response from a guy
  9. Remove Advertisements
