Somebody Please Help me!!!!
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, Somebody Please Help me!!!! in Item Specific Cadillac Discussion; I have a 1968 Deville (472) and I just purchased the front disk brake system from a guy who had ...
    dbird35 is offline Cadillac Owners Member
    Automobile(s): 1968
    Jul 2009
    39
    13
    I have a 1968 Deville (472) and I just purchased the front disk brake system from a guy who had a 1969 deville. I took everything from the spindle out plus the poportional valve...My question is do I need to install the poportional and change my brake lines or can I run the same brake lines that was used for the drums and not install the poportional valve? And If I have to change the brake lines is there a place that sells the brake line pre bent......Somebody Plase Help!!!!
    tripowerbird is offline Cadillac Owners Member
    Automobile(s): 2001 Seville STS
    Oct 2004
    New Hampshire
    50
    Re: Somebody Please Help me!!!!
    You need to install the proportioning valve. If I remember correctly you'll experience rear brake lockup every time you use the brakes. The valve limits pressure to the rear until a certain pressure is reached.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    You also need the master cylinder. A disc brake master cylinder has a check valve within it to keep the pads close to the rotor anticipating the next application. And I wouldn't use anything but a rebuit or new master cylinder! Your lines, hoses should work fine assuming threaded fittings are the same. I would also get new flex hoses for the calipers to make sure they clear the tires and steering linkage.
