Inside of tire wearing = Alignment?
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, Inside of tire wearing = Alignment? in Item Specific Cadillac Discussion; I have a 2000 STS with goodyear 225/55R17 tires. I pulled one of the REAR tires after feeling vibration in ...
    ocgltd's Avatar
    ocgltd is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    Oct 2008
    London Ontario
    300
    I have a 2000 STS with goodyear 225/55R17 tires. I pulled one of the REAR tires after feeling vibration in the car, and discover that although the OUTSIDE still has 4/32 tread left, the INSIDE is worn down to see the white mesh inside the tire. Scary...I only ever checked the outside visually
    The car has 86000 KM on it (53000 Miles), and I suspect these are original tires. I rotated the tires 6 months ago, so maybe the wear is from front wheel usage. But
    My questions are:
    1. What can cause wear on the INSIDE of the the tread? I thought hard driving (which I do) causes outside wear.
    2. Can alignment cause this problem?
    3. Should I get a 4 wheel alignment - or does this car not typically need one so early in its life (Mileage)
    Thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Re: Inside of tire wearing = Alignment?
    Reply is in your duplicate post ^^^.
    225/55/17 or 235/55/17 (OEM tire size - check the driver's door sticker) ?
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    The other post relates to equipment necessary to do a wheel alignment (dealer vs aftermarket). This post is about my vehicle, and the potential causes of sever camber / misalignment.
    rchavez is offline Cadillac Owners Member
    Automobile(s): 2005 cts 3.6
    Jan 2010
    15
    Hello,
    I had the same issue on my 2005 CTS, but I have 20 inch rims. The tire shop said that my car doesn't have any more room to adjust (alignment). He mention going to the dealer and purchasing a cam kit!!!! Not sure if he is correct or was being lazy. I do have the readings from the computer and they show red. I will take it to a different tire shop for a second opinion. Any ideas? Thanks.
  7. Remove Advertisements
