93 seville 4.6l--how do you disable service ride control?!!!
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, 93 seville 4.6l--how do you disable service ride control?!!! in Item Specific Cadillac Discussion; 93 sts w/ 4.6l. strutmaster passive struts.. I purchased this car awhile back- and the dic flashes the "Service Ride ...
    lowdwnsteve is offline Cadillac Owners Member
    Automobile(s): 93 seville sts
    Nov 2009
    41
    8
    93 sts w/ 4.6l. strutmaster passive struts.. I purchased this car awhile back- and the dic flashes the "Service Ride Control" and I've had enough!!
    It has strustmaster "passive" struts in it...I've been searching for weeks and can't find a detailed fix for the annoying "service ride control 84" on the DIC..
    the guy I purchased the car from told me he had the struts installed at his local mechanic- but the idiot mechanic never followed the instructions to disable the code on the dash.-- the harness's in each wheel well are just hanging there...(I talked to Strutmasters, but they won't help me cause I'm not the "purchaser" of the struts)
    .. I've been searching for weeks and can't find a definite fix for this.. I;m assuming a resister would go inline to the harness at each corner to "fool" the computer.. but I need a little more guidance... I did find a "fix" from a member, but he talks about going in through the trunk, and wiring through to a relay under the hood, and hooking up resisters in the trunk etc etc... he talked about 1.5 to 3 ohm.. etc etc... This sounds like it could be just done at each corner instead.
    Can I just hook up resisters to the harness's on each corner with 2 ohm (5 watt) to replicate the factory suspension??
    anyone out there that can help?
    Thanks a ton!!
    steve
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Re: 93 seville 4.6l--how do you disable service ride control?!!!
    thats what i did on my 96sts. i think i used a 12ohm resister at each wheel well though.
