1992 DeVille Squishy brakes
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 1992 DeVille Squishy brakes in Item Specific Cadillac Discussion; Just need some double checking. Have a 92 DeVille w/ 73,000 miles Put on new drums and shoes in March ...
    Sporty883 is offline Cadillac Owners Member
    Automobile(s): 1992 DeVille
    Jan 2009
    Willowrbook, IL
    36
    70
    Put on new drums and shoes in March 09.
    Put on new pads in Aug09.
    Believe they bleeded the brakes in March but not sure about in August.
    Anyways, 2 days ago, brakes got really soft and the brake pedal will eventually go to the floor while i'm holding the brakes on at a stop light. But I do have all of my fluid still in the resivor.
    What would be causing this softness w/o out a fluid leak? Am I getting a air pocket somewhere in the brake line or at the brakes that is causing the lack of stopping power?
    Thanks
    Feb 2003
    california
    69
    6,608
    Re: 1992 DeVille Squishy brakes
    Doing shoe and pad replacement does not require bleeding so if they were bled at all, you would have asked them to do it. A sinking pedal is either a by passing master cylnder or air in the lines. In order of diagnosis I would make sure the rear drum brakes are adjusted, can you hold the car in gear with your foot on the parking brake?,if not, too much clearance, low pedal. Second, have the system pressure bled. Third, if the low pedal remains, replace the master cylinder.
    grannys65 is offline Cadillac Owners Member
    Automobile(s): 92 cadilac devill
    Oct 2009
    35
    11
    Belieave it or not I just got finished replacing the master cylinder in my 92 because it was doing the same thing, I picked mine up at pepboys for $60, took about an hour to install/bleed.
    check it out!
