Front end vibrates/shakes when braking
Results 1 to 8 of 8
Suspension, Brakes and Tires Discussion, Front end vibrates/shakes when braking in Item Specific Cadillac Discussion; I have a 2001 Deville DTS with 73K miles on it. I noticed about 8 weeks ago every time I ...
    mklano is offline Cadillac Owners Member
    Automobile(s): 2001 Deville DTS
    Nov 2007
    34
    I have a 2001 Deville DTS with 73K miles on it. I noticed about 8 weeks ago every time I would begin to break, whether hard or over a long distance, the front end would have some medium vibration/shaking. I bought new EBC rotors and pads and put them on the front end. Same problem continued for two more weeks until I put on new re-built calipers. Same problem. I bought new tires, same problem.
    Sometimes it feels like something keeps griding or hitting the same place as the tire turns. When I took everything off to put the new calipers on the two week old pads and rotors looked fine, no unusual wear. The vibration sometimes feels like griding and then it goes back to vibration.
    I probably will do the back breaks to see if this helps. Any thoughts or recommendations would greatly be appreciated!
    Thanks.
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    Re: Front end vibrates/shakes when braking
    i have a shaking when breaking in my car at higher speeds
    i have a 2000 seville you have a deville not sure if it could be the same as mine
    my mechanic told me that its most likly my rotors that are warmed or rusted and they just where not replaced
    when the old owner did the breaks
    so he said that that will probalby take care of the shaking when i get the cash to have them doen
    so that might be why yours is doing that also
    Kzfl8y is offline Cadillac Owners Member
    Automobile(s): 2005 Deville DTS
    Dec 2009
    Rhinelander
    11
    My 2005 Deville DTS w/ 90,000mi does the same. I have order 4 performance rotors and pads. I hope it's not a wheel bearing or CV joint. I will report back when parts are installed, good luck.
    keelerdr is offline Cadillac Owners Member
    Automobile(s): 1997 Deville D'Elegance
    Sep 2009
    Southeastern PA
    43
    Hey,
    I had a somewhat similar problem although it was a slight vibration/light pulsing when I would brake (it never felt/sounded like a grinding noise). It kinda felt like it was coming from the front but it was hard to tell. I took the car in and had the brakes looked at, turns out all that was needed was for the drivers side rear brake to be "turned" (I'm assuming on a mill that shaves off the face of the rotor to make it all smooth again). The rotor was slightly warped.
    It was weird that it was only one rotor that needed it and also odd that the whole car seemed to vibrate/pulse... I could not tell it was the rear brake or that it was driver side just from the symptoms. Not sure if this will help but it is inexpensive to have someone just take a look at the rear brakes so it can't hurt.
    Hope this helps.
    SFTX is offline Cadillac Owners Member
    Nov 2013
    1
    Quote Originally Posted by Kzfl8y View Post
    You posted this in 2009. Did you ever get the time to install new rotors and pads?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,845
    Quote Originally Posted by SFTX View Post
    If you click his username and view his profile you'll see that he hasn't logged in for 2 years. I doubt that you'll see an answer.
    http://www.stoptech.com/technical-su...nd-other-myths
    Cheriedg is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    May 2014
    38
    I as well have some moderate shaking when brakes are applied to my 2000 Deville. The steering wheel does not shake at all. Have any suggestions and is it safe to continue to drive ?
    Copied from Suspension to Deville
    Feb 2006
    55,845
    Cherie,
    This thread has been dead for 6 months. I copied your question (common problem, yes, it's safe to drive) up to the more active Deville forum.
  11. Remove Advertisements
