1999 STS Front End Creaking
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, 1999 STS Front End Creaking in Item Specific Cadillac Discussion; I posted this in the Seville Section with no replies...its been this way since I bought the car back in ...
    jcresciSTS is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Cadillac Seville STS (November 2012, 183k)
    Jul 2009
    South San Francisco, CA
    29
    968
    I posted this in the Seville Section with no replies...its been this way since I bought the car back in May. Well when I test drove it it was fine and when I was driving it home the next day it was fine, when I got home is when the noise appeared (of course that would happen). Anyways...
    Well I'm still not sure what it is since I haven't had it checked out but when I got to work I pushed on my car from the side and no noise. I went to the front bumper and stepped on it and heard the noise. It also happens when driving.
    Like I said in my other post a long time ago, its a creaking noise but I guess a better way to describe it is that it sounds like something is "popping". My guess is my strut?
    I just did a little video from my phone and got a sound recording. This noise is actually coming from the passenger side...this whole time I thought it was my driver's side.
    Now in keep in mind a mechanic from a shop I went to said it was my LCA bushings on both sides...I can only hear this noise on the passenger side so I'm 99% sure he was bs'n me
    Here is audio of the noise:
    http://www.box.net/shared/6iothguehu
    [youtube]FBY8xOKe-NI[/youtube]
    derone is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac STS
    Aug 2007
    NC
    133
    Re: 1999 STS Front End Creaking
    Might be the swaybar frame(inner) bushings. You can spray them with wd40 to see if the noise goes away temporarily. wd40 evaporates so no harm done to the rubber. I use a mix of silicon grease and powered graphite for a permanent cure.
    Jul 2009
    29
    968
    Thanks, I'll give it a try tomorrow
    What would the process be for the permanent cure?
    KARL DAHLEN is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 2008 STSV6 RWD
    Sep 2008
    Virginia
    74
    266
    It is the torsion bar bushings. There should be a TB on it. There is a new type of bushing and clamp to fix it.
  7. Remove Advertisements
