I have an OBD code T077 = PCM serial data link com error so I went to clean the ground connections and found the stud that the ground wire connects to just spins in place.
I noticed the part of the pump where the stud enters has two security bolts and looks like it could be removed fairly easily.
Anyone have experience with these ABS/TCS, is it worth trying or even possible to fix?
