Any vacuum tubes part of the break system?
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Any vacuum tubes part of the break system? in Item Specific Cadillac Discussion; I have a problem with breaks, the ABS light and traction dissabled message appear after a few miles of driving. ...
    Freakzilla is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Deville 4.9L 200,000m
    Jun 2009
    Douglasville, GA
    45
    498
    The code says FL wheel speed sensor but I have replaced the hub assembly and checked the circuit for continuity.
    While underneath this weekend, I found a vacuum line reducing connector that was loose on one side, the tubing had become hard and brittle and cracked. There was a little debris in the connector.
    I have no idea what this is for, but it was behind my LF wheel. I couldn't tell where it came from or where it goes, could it be related to my break problem?
    I got a soft coupler, a connector and some new tubing to try to reconnect it but I'm afraid the line may clogged.
    Anyone know what that vacuum tube does?
    Jun 2009
    Douglasville, GA
    45
    498
    Re: Any vacuum tubes part of the break system?
    1995 Deville 4.9L, BTW.
