No rear End Traction!!!
Results 1 to 8 of 8
Suspension, Brakes and Tires Discussion, No rear End Traction!!! in Item Specific Cadillac Discussion; I just purchased a 2002 STS ( build date 02/02) and the Rear End Bounces Bad. If Cornering on uneven ...
    TANGLDWEB Guest
    QuestionNo rear End Traction!!!
    I just purchased a 2002 STS ( build date 02/02) and the Rear End Bounces Bad. If Cornering on uneven Surfaces the rear end wants to Pass the front. When driving straight and level, the ride is Slightly more stabil with trac control Off, but cornering gets Scarry! Have Maintenance Manuals on the way but have not had much time to Diagnose other than determining that, not only does the Rear End Bounce when you push down on the Vehicle while stationary and running, but that the Passenger side is Worse than the Drivers. Act just like worn Out Shocks as with a Non Ride controlled Vehicle. No Onboard Warnings Either, will also run OBDII again. Any Suggestions on what to look for in the mean Time?.
    TANGLDWEB Guest
    Re: No rear End Traction!!!
    And though it's 12:44am I looked at the Spare Tire Cover and there it is "F55". Now on to point "B"!
    TANGLDWEB Guest
    ... And H tire rating. Guess another Question is if the Speed Rating (limiter) can be reprogrammed,.. Probably. Aint goin that fast Anyway till it's Fixed and stay on the road. Still Love This Car!!! USA USA
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,594
    Your speed limiter is set for 130. Exactly how often do you intend to go faster ?? I bounce my limiter several times a month - rural roads are fun - but 130 in a 4,000 lb. sedan is fast enough.....AJxtcman can remove the limiter. So can Wester's Garage. $300, 4 day turnaround with your PCM.
    Start the car, open the trunk. You and one or two friends sit on the trunk lip. Does the level compressor come on and return the rear to a just slightly raked position? Everybody hop off - do you hear air escaping in the RR wheelwell ? If not, jack up the car and pull the right rear wheel. Check to make sure the level control link is attached to the suspension arm. If that's OK, you're in the level ride compressor replacement business - inside the RR fenderwell liner. Not hard.
    CORSA
    TANGLDWEB Guest
    Oh,.. It's kinda a Guy Thing you know,.. dont want to have ANY Limits on my Ride!!! : ) I hear the compressor and it runs momenteraly and shuts off indicating theres no severe leaks or breaks and must be getting information as to pressure, but I do not hear it decompress. Did this a couple of times with the same result but an actual change in Rake is barely noticable. Have Fac Serv Manuals on the way and they may have a way to test the Compressor. I'll be learning the in's an out of this car,.. It's a Keeper! But you already Knew That. THANKS
    Feb 2006
    56,594
    ...............I just posted all this again, up in your sort of parallel thread ^^^ there.
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    40
    721
    Sub, will the shocks cause it to travel like that? This 98 is like that, i was slowing down going up a rough paved hill and the rear was drifting to the right. I notice it tries to shake right to left when i hit one-sided bumps or pot holes and sewers. I thought it was a sway bar issue, but i know the valve on the air compressor isnt working, so no air, and there is a pretty big rip on the outside of the rubber on the passenger side shock. Well i have shocks, and i can get a compressor cheap.... but i was ready to replace the whole rear end. Im really not farmiliar with the 98+ rear suspension yet. Looks like mars under there compaired to the older ones...
    DevilleDeeman's Avatar
    DevilleDeeman is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4 Premium, Saturn Vue XR
    Sep 2008
    Ontario, Canada
    48
    480
    Sounds like the fluid burst from your shocks...take it over RR tracks and see if the car bounces to the side, if it does that's the problem. Same thing happened on my past 2003 Deville. Replaced the ride leveler shocks at Arnott industries, the car was like brand new after the replace.
  11. Remove Advertisements
