2000 Seville can i put 22s on without rubbing ?
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, 2000 Seville can i put 22s on without rubbing ? in Item Specific Cadillac Discussion; Hi i was wondeirng what is the biggest size i can go up to with a 2000 seville stock will ...
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,688
    Hi i was wondeirng what is the biggest size i can go up to with a 2000 seville stock will 22s rub ?
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,825
    Re: 2000 Seville can i put 22s on without rubbing ?
    If you keep the original outside tire diameter of close to 26.2" and maintain the original section width, nothing will rub. You can put 26" wheels, no tires on.
    Go to www.tirerack.com and use their tire size tables and different tire brand sizes to compare with the specs on the tire listed on your driver's door sticker. Don't forget, if you get crazy with tire sizing you throw the speedo and transmission settings off.
    (BTW, the car will look and ride like hell.) Look at 18" Deville/CTS 10-spokes, max. www.wheelcollision.com, click on the little pic to get a better view of each wheel.
    ThumperPup's Avatar
    Mar 2009
    37
    7,688
    i was thinking of doing 20s or 22s no bigger
    but tire rack i looked and they only say that 18s will fit
    dalamak is offline Cadillac Owners Member
    Automobile(s): 2001 SLS, 1997 STS, 71 Eldo
    Feb 2009
    North Jersey
    76
    I personally wouldn't go that big, but if you do try you better do shows and springs, you don't want a saggy suspension. Not sure what a F55 Suspension is but if its stiff go for it, but most caddy's I see have a lot of body roll
    I'm personally doing 18" with a ebiach kit
    Quote Originally Posted by PupFromCleveland View Post
    Feb 2006
    56,825
    F55 suspension in the SevilleTS began in January of 2002 (late '02 model run). It is the same DELPHI/Lord Magnetic Ride Control used in the same year(s) Corvette and Ferrari, then adapted to several other GM models later.
  8. Remove Advertisements
