99 deVille, Level Ride won't come down
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, 99 deVille, Level Ride won't come down in Item Specific Cadillac Discussion; I have a 99 deVille. My rear Level Ride shocks are fully pumped up and will not come down. There ...
    LEENHOUT is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    3
    Unhappy99 deVille, Level Ride won't come down
    There are no warning lights on the dash.
    Can anyone tell me where to look? Where to start?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,877
    Re: 99 deVille, Level Ride won't come down
    Jack up the rear and use jackstands. Pull the wheels and check the ride height sensor link on top of the right rear suspension arm. The link sometimes disconnects from either the control arm ball or the sensor itself. If thst's not the problem, disconnect and clean any shock or suspension connectors you may find.
    Read the stickys at the top of the main forum pages on how to pull your trouble codes from the DIC......it's all built into the car. You may see a suspension fault code that will give some guidance.
    Aug 2007
    3
    Thank you for your input. We are going to pull it apart and see what we find.
    slsonvogues is offline Cadillac Owners Member
    Automobile(s): 2001 Seville SLS 140k miles
    Feb 2009
    28
    50
    Did you ever find the problem? Im having the same exact issues with my 01 seville SLS and do not know how to fix it
    Feb 2006
    55,877
    SLS, Go up and look at your original post in Seville/Eldorado.
    Aug 2007
    3
    We had to have it fixed. It was a wire connected to a switch.
  9. Remove Advertisements
