rear end up and a rough ride
Results 1 to 7 of 7
Suspension, Brakes and Tires Discussion, rear end up and a rough ride in Item Specific Cadillac Discussion; Hey group. The wife informed me that since I had put new tires on her 98 Deville the ride was ...
    56nomadman is offline Cadillac Owners Member
    Jul 2004
    6
    Hey group. The wife informed me that since I had put new tires on her 98 Deville the ride was real rough. When I check, I found the rear end extended up as far as it would go and the shocks have no give. I did disconnet the air hose from the compressor for a few minutes but no air was released. My guess is the good guys at the tire store turned the key on after the car was on the lift and the level extended to max. I have called several dealers but as usual they say it is something that has to be fixed by them. Any ideas on how to reset it?
    Thanks in advance
    caddyshack24's Avatar
    caddyshack24 is offline Cadillac Owners Enthusiast
    Mar 2004
    Florida
    36
    599
    Re: rear end up and a rough ride
    what about the front? im thinking they might have unplugged a sensor for the ride control and the stocks / struts were commanded to firm mode.
    your reason make perfect sense too.. dont know how you would fix that, sorry
    Jul 2004
    6
    Well guys and gals I think I figured it out. I removed the rear wheel (drivers side) and unplugged the air line going to the shock. After all the air had escaped from the shock and line, I plugged it back in, mounted the tire and drove it awhile. Things look and feel normal. This may not always be the fixer but it is worth a try.
    After the bride gives it the thumbs up, I think all will be well at the 56nomadman's house and I can get back to working on .............yep you guessed it........ my 56 nomad.
    Have a safe 4th of July and Pray for our sons, daughters, loved ones and friends who are helping others have the freedom we all have.
    WILLARD WINN is offline Cadillac Owners Member
    Automobile(s): 2005 DEVILLE
    SOUTH CAROLINA
    69
    10
    Thumbs upRe: rear end up and a rough ride
    YOU ARE CORRECT TOOK THE REAR WHEELS OFF AND TOOK THE SHOCK LINES LOOSE, LET THE AIR OUT AND NOW ALL IS GREAT.... THANK YOU FOR THE HELP
    WILLARD WINN
    smooth3d is offline Cadillac Owners Member
    Aug 2004
    Tulsa,OK
    68
    how hard is it to unplug the air line? I think im having the same issue?
    Jul 2004
    6
    SmileRe: rear end up and a rough ride
    Sorry I just looked at the post again. It isn't hard at all I took the left rear tire off.(drivers side rear) and just umplugged the air hose. Make sure you let it stay off for awhile as it has to loose alot of air. Hope this helps!!!!!
    rastamon is offline Cadillac Owners Member
    Sep 2005
    1
    TalkingRe: rear end up and a rough ride
    Hey Willard!
    Were you in Basic Training at FtPolk in 10/66 with a DI named Sgt.Murphy ....just wondering. Bet he has a Caddy! LOL take care, Earl Boehm eb6147@yahoo.com
  10. Remove Advertisements
