Front struts for 2000 sts
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, Front struts for 2000 sts in Item Specific Cadillac Discussion; I just purchased a 2000 STS with 65k. I believe I need new struts in front and was told they ...
    cervini auto is offline Cadillac Owners Member
    Automobile(s): 2000 STS
    Feb 2009
    9
    I just purchased a 2000 STS with 65k. I believe I need new struts in front and was told they are 400+ dollars each. I heard the pump (in the back of the car) come on for about 5 seconds after I started the car a couple of days ago, but have not heard it come on ever since, and when I hit the slightest bump in the road it feels like the front of the car is bottoming out. Can someone lead me in the right direction to find out what I need to repair this problem, I do not know if the struts are bad or a sensor is bad or the pump is going bad etc... any help will be greatly appreciated. Rich.
    ejguillot's Avatar
    ejguillot is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    Jul 2006
    Tampa FL
    42
    985
    Re: Front struts for 2000 sts
    Do some searching and reading. If you need all 4 struts and are price sensitive, you might consider a passive strut conversion kit.
    I replaced my 2 front struts last year, and spent $1000 in struts and strut mounts alone. Installed them myself.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,830
    The ELC pump in the rear has nothing to do with the front struts. It proves out and preloads the rear shocks just after "key on, engine on", KOEO, in order to level the rear suspension. To test it, listen for the proveout, then open the trunk and 2 persons sit on the trunk lip. The pump should run and level the rear. When the people stand up, removing the load, the system exhaust valve (RR fenderwell) should open and vent off to return the rear to level.....actually just a tad higher than the front.
    Front springs and struts are a different critter.......
    Feb 2009
    9
    Thanks for the information, Rich.
  7. Remove Advertisements
