B2118 - Front Vertical Sensor Failed
Results 1 to 8 of 8
Suspension, Brakes and Tires Discussion, B2118 - Front Vertical Sensor Failed in Item Specific Cadillac Discussion; Can somebody tell me what this code means? Where is this sensor located & can I get to it myself? ...
    Tommy Deville's Avatar
    Tommy Deville is offline Cadillac Owners Enthusiast
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    I keep getting Car will not exceed 90 mph but have no idiot lights flashing.
    this is the only code throwing current.........
    I'm trying to sell the car & I really don't wanna sell it with any current codes or issues.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,179
    Re: B2118 - Front Vertical Sensor Failed
    Something has gone wrong with the Stability Control system. Try opening and cleaning the front strut sensor connectors. Pull the front wheels and disconnect the strut wiring, not the wheel hub/brake wiring. Spray with electronic cleaner and reconnect. Pray.......
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    I was leaning towards that too.
    I had a feeling it was the front struts, they are passive with the new plug in system, no resitor. I was thinking one of the plugs got some water in it because it started during the last snow storm & stopped once it dried out.
    I have to look and see where they put those connections, they did tell me, but I can't remember what they said.
    TY Subby
    Cliff8928 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Jul 2008
    Long Grove, IL
    36
    416
    Haha... That's funny.. B2118 is a Front Vertical Sensor in the driver's seat
    Most likely your memory seat doesn't work right, correct? (just the front vertical adjustment)
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    No, it works fine.
    Jul 2008
    Long Grove, IL
    36
    416
    Well, that's what the code is for. The service info says that your front vertical adjustment will not work automatically for the seat recall or entry/exit functions. It will still work manually though.
    So if you raise or lower the front of the seat, then in theory it should not automatically adjust back to where your memory settings are. At least if the code is current. If the memory seat module sees a valid signal again, it will clear itself.
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    Hmmmmmmm that's intresting, I'll check it out. Last I used it which was Saturday it seemed fine.
    I'll clear em' out & see what happens
    Feb 2006
    56,179
    That's what one gets for shooting from the hip.......just checked my Alldata DTC list and B2118 doesn't even exist for 2002.........Sorry !!
  11. Remove Advertisements
