1990 cadillac seville abs brakes
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, 1990 cadillac seville abs brakes in Item Specific Cadillac Discussion; can you convert a 1990 cadillac seville from abs brake to regular brake cause i have a hard brake pedal ...
    cadi seville is offline Cadillac Owners Member
    1
    Exclamation1990 cadillac seville abs brakes
    can you convert a 1990 cadillac seville from abs brake to regular brake cause i have a hard brake pedal and antilock brake light stays on and brake light stays on
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,465
    Re: 1990 cadillac seville abs brakes
    Get it checked before you do anything. It could be another brake problem causing it.
    poodad is offline Cadillac Owners Member
    Sep 2005
    sounds like abs pump or master cyclinder
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    First check the codes. If the computer knows to put those lights on then it knows something about the problem.
    It sounds more like a powerbooster issue to me. ex. insufficient vacuum to the power booster, caused by a vacuum leak somewhere, or Bad check valve.
  7. Remove Advertisements
