rear suspension blues
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, rear suspension blues in Item Specific Cadillac Discussion; Ok in january I changed all four struts because the back end was rocky. Then when I changed it the ...
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    33
    1,498
    Ok in january I changed all four struts because the back end was rocky. Then when I changed it the rear end wasn't rising so I came to the conclusion the compressor was bad and when I turned the compressor on when the car was off it made a whine.. So now I changed the rear struts wit monores and a used compressor still no telelight and no rise in the back I moved the knob on the lever that connects to the right tire and nothing. Whats wrong with this car. Is there a way to bypass the old compressor wiring add new wiring to get it to work. Ex compressor elc leveler and struts. I looked on my manual and it says there is a pressure limiter value is this a major part in the air line because I plan to run new airlines
    Apr 2007
    san diego
    33
    1,498
    Re: rear suspension blues
    Here is a bit of good news the car was low when I parked it and so I ran the compressor straifht to the batery and the car went up so you all think its the levler or a relay
