Rear shocks stay up-help-99 Seville SLS
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, Rear shocks stay up-help-99 Seville SLS in Item Specific Cadillac Discussion; On My 99 Seville SLS the rear shocks stay up all the way and the car rides like a rock. ...
    jerry23 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    24
    UnhappyRear shocks stay up-help-99 Seville SLS
    On My 99 Seville SLS the rear shocks stay up all the way and the car rides like a rock. The compressors sounds like it is staying on all the time. I don't have any codes. Can anyone help me to release the shocks until I can repair the problem whatever it may be? I need the car to go to work and in this economy that is a luxury.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Re: Rear shocks stay up-help-99 Seville SLS
    The compressor and sensor are located inside the right rear fenderwell. Jack up the car and pull the wheel. The height sensor arm is attached to the lower suspension arm. If it has become disconnected it will send a false height signal to the system, possibly giving the compressor a bad run command.
    Check the connectors and wiring for integrity.
    slsonvogues is offline Cadillac Owners Member
    Automobile(s): 2001 Seville SLS 140k miles
    Feb 2009
    28
    50
    Did that fix your problem? my 01 SLS is having the same issues but the sensor seems to be connected
    Feb 2006
    55,850
    SLS, Go up and look at your original post in Seville/Eldorado.
  7. Remove Advertisements
