02 Deville Traction Control light
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, 02 Deville Traction Control light in Item Specific Cadillac Discussion; My traction control light on my dash keeps coming on and off. Does anyone know why this is happening?...
    Deville2002's Avatar
    Deville2002 is offline Cadillac Owners Member
    Automobile(s): Cadillac Deville
    Sep 2008
    1
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    Re: 02 Deville Traction Control light
    Read the stickys at the top of Deville and Northstar to find out how to pull the DTC's (Diagnostic Trouble Codes) from your car's instrument panel display by using the 3 buttons to the right of the panel. You do not need an aftermarket scanner. Write down the codes, noting whether they are History or Current. Then come back here......
    Something is sending an incorrect wheel speed or mismatch to the PCM, which is trying to stop a wheel from slipping or skidding. Any new tire changes or curb damage ? Good tires ? Aggressive driving ??
    tommytone is offline Cadillac Owners Member
    Jul 2007
    6
    I also have a traction control light problem. 00 Deville. Only comes on at night and when I hit my turn signal. During the day I have no problems with it. Seems its something with the lighting system causing the problem. When dusk arrives I hit my turn signal switch and the Traction Control light warning comes on and when I hit the button on the shift handle I have nothing displaying traction control. Like I said, during the day morning till dusk it works as advertised. Anyone know of any bulletins? I also have no codes.
