Go Back   Cadillac Owners Group > Cadillac Technical Discussion > Suspension, Brakes and Tires
Suspension, Brakes and Tires Discussions relating to improving the handling, ride and stopping-power of your Cadillac.
Cadillac Forums: Replacing front bearing/speed sensor: which manufacturer?
Old 07-05-08, 09:48 PM
spotty spotty is offline
Cadillac(s): Cadillac
View spotty's Photo Album
Casino Cash: $360
1996 Concours, 150K miles
It looks as if I have bad speed sensors on the two front wheels (TC0023/TC0027), so I am getting ready to replace the speed sensor/hub assemblies. Rock Auto has parts from four manufacturers: Raybestos, Timken, BCA/National, and ACDelco. Does anyone have relative quality recommendations regarding these different makers?
I also wonder about the speed sensor wiring harnesses, which have been flexed for 12 years. It's sure easier to swap one out than to take the hub off, but retail price is over a hundred bucks. I might try doing that first.
Advice welcome!
  #2 (permalink)
Old 07-05-08, 09:58 PM
submariner409's Avatar
submariner409 submariner409 is online now
If it won't run, chrome it !
Cadillac(s): 2002 Cadillac F55 STS/48000mi., 2004 Ford F150 Super cab 4x4
Casino Cash: $9769
Re: Replacing front bearing/speed sensor: which manufacturer?
Take the easy road first: Pull the sensor pigtail connectors, shoot 'em out with electronic cleaner or brakleen and see if that helps. While you're in there, check out the wiring, and try to rock the wheel in and out, holding it at 12:00 and 6:00. Any play points to new capsules.
Buy American........at least we can still properly harden bearing assemblies.
  #3 (permalink)
Old 07-07-08, 04:28 AM
Casino Cash: $360
Thanks for the suggestion: I cleaned the contacts on both ends of the speed sensor harnesses (one end in the engine compartment, the other end at the wheel). No improvement.
The shop manual indicates a normal resistance range of 900-1300 ohms for the speed sensor. Mine measured 1150 from the top end of the harness, so it's a bit of a puzzler. I decided to try various resistances across the connector that goes back to the EBTCM to see if I could characterize the range it considered acceptable. Anything over 1100 caused the code to be set. I went down as low as 800 without setting the code, and then went back up to 1500 and still couldn't get the code to set. Plugged the sensor back in and all OK (for now).
It's acting like a bad ground somewhere. Guess I need to spend some more "quality time" with a voltmeter inside the engine compartment.
  #4 (permalink)
Old 07-07-08, 11:24 AM
mighty_quad4's Avatar
mighty_quad4 mighty_quad4 is offline
Cadillac(s): 2000 Seville STS
View mighty_quad4's Photo Album
Casino Cash: $2355
if its bad, buy Timken. though most are made in USA some are made in India. there is not diffrence in quality between the two other than what you might perceive. cant comment on the other brands when it comes to bearings. Timnken is all ive ever used when it came to aftermarket replacements.
  #5 (permalink)
Old 07-07-08, 12:48 PM
vanaisa's Avatar
vanaisa vanaisa is offline
Cadillac(s): ´67 Eldorado, ´96 Eldorado
View vanaisa's Photo Album
Casino Cash: $3077
I located Dorman wheel bearings on ebay - are they OK?
bearing or speed, front, manufacturer, replacing, sensor
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
