I am plagued with brake "problems"
I put ceramic pads & new rotors on the rear, last fall, I think.
Now when braking at high speeds the whole car shakes like crazy.
It's not felt in the steering wheel or brake pedal...which makes me think it's the rears causing the shakes.
Every time I take of off the rear brakes the caliper pins are always dry. They have some rust on them, which I always clean off with some steel wool. Aren't they always supposed to be greased with caliper pin grease? I always put it on, am I not putting enough on? I feel like it's running out somehow, and I can't figure it out.
My other theory is that the parking brake is not releasing, and will probably just disconnect the cable and stop using it to remove that variable from the equation.
I've always done my brakes on both our vehicles for as long as I've learned how.
- I always use new rotors & pads
- I always use anti squeal compound on the backs of the pads
- I always clean off the calipers where the old anti-squeal compound was.
- Make sure the hub surface is clean
- re-apply high temp caliper grease to caliper pins.
- Torque lug nuts to 100 ft lbs.
If the pads have worn at an angle instead of flat I am guessing the warranty won't cover that. but i'm going to look for my receipts when I get home and call the store I bought them from.
Any tips would be helpful. Thanks!
