Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: TCS C1243 on 98 Deville
    nickpitlosh is offline Cadillac Owners Member
    Automobile(s): 2008 DTS
    Apr 2007
    None
    25
    Hello
    I've looked through the forum quite a bit, I'm looking for information on troubleshooting c1243. If someone could post the diagnostic steps for this code, an pictures of what the ABS pump looks like with its location, I'd be most grateful. This is the first car that I bought all on my own and I need some assistance locating some of this stuff.
    Also is anyone here in the lansing, MI area?
    Rantaholic is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    3
    Re: TCS C1243 on 98 Deville
    I would also be interested in this info
    thanks
    Cliff8928 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Jul 2008
    Long Grove, IL
    36
    416
    Quote Originally Posted by GM
    DTC C1243 BPMV Pump Motor Stalled
    Circuit Description
    When the EBTCM grounds the pump motor relay, the relay closes and provides battery voltage in order to operate the pump.
    Conditions for Setting the DTC
    All of the following conditions occur:
    After the pump motor has been ON, the pump motor relay is commanded OFF.
    The pump motor was ON.
    The EBTCM detected a stalled or slowly turning motor.
    Action Taken When the DTC Sets
    A malfunction DTC is stored.
    The ABS/TCS/Stabilitrak® is disabled.
    The ABS indicator is turned ON.
    The TRACTION CONTROL indicator is turned ON.
    The DIC displays the SERVICE STABILITY SYS message.
    Conditions for Clearing the DTC
    The condition for DTC is no longer present and you used scan tool Clear DTCs function.
    The condition for DTC is no longer present and you used the On-Board Clear DTCs function.
    The EBTCM does not detect the DTC in 50 drive cycles.
    Drop me a PM with your email if you want the rest in a PDF.
  5. #4
    Apr 2007
    None
    25
    It would seem that I can't use the pm system yet. If you could, please forward that to my username here at gmail.com
  6. #5
    Jul 2008
    Long Grove, IL
    36
    416
    Yeah, you need 10 post minimum I believe...
  7. #6
    Caddie Man is offline Cadillac Owners Member
    Automobile(s): 1998 Sedan Deville
    Mar 2010
    Buffalo, N.Y.
    53
    11
    Here is an image of the B.P.M.V and the A.B.S. motor's location. It's on the driver's side of the vehicle behind the front tire.
  8. #7
    Mar 2010
    Buffalo, N.Y.
    53
    11
    The next step in fixing this c1243 code would be to pull the A.B.S. motor off the Brake Pedal Modulator Valve. First disconnect the ground wire and then remove the bolts that hold the electric motor on the valve. The bottom bolt on mine was on there really good. I striped the head on the bolt so I drilled the head off the bolt to get the motor off.
  9. #8
    Mar 2010
    Buffalo, N.Y.
    53
    11
    As you can see in the image above...I had to weld a nut on the bolt to extract the broken bolt off the unit. Here is the result...bolt extracted!
  10. #9
    Mar 2010
    Buffalo, N.Y.
    53
    11
    The next step is to take the motor to a vice and using a chisel or screw driver split the cap off the top of the motor. This unit was not made to be serviceable so you're gonna have to use some finesse removing the cap. On my unit the clips on the housing that hold the magnets in place where deteriorated, so I went to the junk yard and picked up another motor for $20.00. I took this motor apart and using a center punch I knocked out the rivets holding the clips in place. Then I took the clips to a grinder to remove the rest of the rivet that was still on the clip. I then found some small nuts and bolts and used them to connect the clips to the housing. Here's what it looked like when I was done.
  11. #10
    Mar 2010
    Buffalo, N.Y.
    53
    11
    The next step is to put the motor back on the unit.
  12. #11
    Mar 2010
    Buffalo, N.Y.
    53
    11
    Next you have to put the circuit board with the brushes on it in place.
  13. #12
    Mar 2010
    Buffalo, N.Y.
    53
    11
    Ok, we are almost done. Now put the cap on the motor and put the bolts back in that hold the motor to the unit. After that...connect the ground wire and you're done. This solved my c1243 issue. Lights are off the dash and first gear is back. Hope this helps others out there. The whole project took me three hours to complete and cost me $20.00. GOOD LUCK!
  14. #13
    Mar 2010
    Buffalo, N.Y.
    53
    11
    A new Brake Pedal Modulator Valve cost $1,287.00 from the dealer. No thanks, I'll rebuild my old motor.
  15. #14
    Mar 2010
    Buffalo, N.Y.
    53
    11
    How do you delete a post?
    Last edited by Caddie Man; 03-31-10 at 10:34 AM. Reason: I want to Delete this post!
  16. #15
    69
    82,272
    Caddie Man, this thread is over a year old, but this would be a nice addition to the Tech Tips section if you can repost it in one post.
  • You may not post replies
