any one know where i can get a level control valve
Results 1 to 11 of 11
Suspension, Brakes and Tires Discussion, any one know where i can get a level control valve in Item Specific Cadillac Discussion; iv looked in the junk yards around here i cant find nothting i was just wondering if any one knew ...
    Xmugsyx's Avatar
    Xmugsyx is offline Cadillac Owners Member
    Dec 2003
    NyC
    35
    93
    iv looked in the junk yards around here i cant find nothting i was just wondering if any one knew any where on line cuz i hate the dealer ship .. and i doid not see it on buy oem parts.com
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: any one know where i can get a level control valve
    If you're looking for the valve that sits on top of the compressor, it's p/n 12494813. Good luck.
    Xmugsyx's Avatar
    Dec 2003
    NyC
    35
    93
    yeh it sits in the top of the compressor... thats the auto level valve right cuz it has the funky round thing on the side of it with the 2 black plastic lines that push the air in so it can tell if its got a load on it ???? im guessing ??
    El Dobro's Avatar
    Sep 2003
    1,471
    It goes for about $143.00 from a dealer. Check around on the net for a discount.
    Xmugsyx's Avatar
    Dec 2003
    NyC
    35
    93
    i found it from buy oemparts.com it says Rear suspension - Ride control - Head
    HEAD, All Models 1992 - 1995 .. thats the level control valve ???
    Caddymom is offline Cadillac Owners Member
    May 2004
    Arkansas (I-30 the land of orange barrels)
    Hi, we just replaced this on my car. The compressor had stoped running and it set a code c1738 Exhaust solenoid valve short to ground. I found the entire compressor assembly at a local auto salvage for $100. We decided to get just the head assembly for the compressor our GM dealership because it had a 12 month warranty (just what you didn't want to do, sorry). We talked our dealer down from $150 to $106.
    Good luck,
    Caddymom
    Xmugsyx's Avatar
    Dec 2003
    NyC
    35
    93
    so the level control valve is in the head i will replace the hole head if i have to cuz i know the compressor is good cuz it kicks on here and there and some times i get the coad level control valve short to ground open .. i just need to know def befor i go spending 120 on the compressor head that that is where the level control valve is
    May 2004
    The exhaust valve IS in the head assembly...we took the whole thing apart.
    Just to make sure that the valve was bad we checked the two white wires that run from the head assembly (solenoid exhaust valve) for voltage. The circut was staying open.The mechanic we talked to said that would signal the cvrss to shut down before the pump ran so much that it burned out.
    Once a code is set the compressor will not come on until it can complete a closed circut.
    We did one other thing we did to make sure that it was the exhaust valve that was malfunctioning. After the compressor assembly was removed from the car (with the air hoses attached)...we direct wired it to the battery. The compressor ran just fine. After a few seconds to lift the suspension we stopped and hooked the electrical wires back up to the car. As long as the car's ignition was off, air stayed in the bags. As soon as the car's ignition was turned on the air was released. We knew that the cvrss was still recieving the signal that the slenoid exhaust valve was staying open.
    Thanks,
    Caddymom
    Xmugsyx's Avatar
    Dec 2003
    NyC
    35
    93
    thanks bro i just ordered the head when it gets here i will let ya know how iot all turns out
    Nicnatros is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac STS
    Apr 2005
    13
    Who did you order a head from and how much was it? From this thread, it looks like I will be needing one also.
    oldgamer's Avatar
    oldgamer is offline Cadillac Owners Enthusiast
    Feb 2004
    Staten Island, NY
    577
    Quote Originally Posted by Nicnatros
    I ordered used compressor on-line and it was really cheap ($51 including shipping). The guy says he checked compressor and it's ok, but he can't check the valve. When it came I check the valve and it was Ok. I replaced old compressor myself, it wasn't very hard. Now it's fine. So, whole thing was $51 to me. And it's easier to change compressor than compressor head.
  14. Remove Advertisements
