upper ball joint replacement - 1975 Commercial Chassis
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, upper ball joint replacement - 1975 Commercial Chassis in Item Specific Cadillac Discussion; I recently scored a 1975 Commercial Chassis (a former Miller-Meteor hearse) where the upper control arm bushings are shot, and ...
    montrosepatriot is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    4
    I recently scored a 1975 Commercial Chassis (a former Miller-Meteor hearse) where the upper control arm bushings are shot, and I have plans to replace the ball joints.
    cadillac_tech is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX
    May 2007
    Parker , CO
    403
    Re: upper ball joint replacement - 1975 Commercial Chassis
    Good luck with that.
    Oct 2007
    4
    The Motor manual which I have in my office states that the entire upper a-frame must be replaced if ball joint replacement is likely; to date, no Cadillac dealer will stock parts for a pre-1977 RWD.
    milehighassassin is offline Cadillac Owners Member
    Nov 2007
    Vail/Fort Collins, CO
    38
    13
    Quote Originally Posted by montrosepatriot View Post
    Anyone find anything here? I need to replace a ball joint on a 1973 Deville
  7. Remove Advertisements
