Originally Posted by 03cummins Hello,
I have a 2000 SLS with the change brake pads message displayed as well. The front pads were worn so I had the rotors turned and replaced the pads and the sensors because the clips that hold them in the pads were broken. I also replaced one of the rear sensors because it looked a bit thinner than the rest but to no avail. The message still comes up even after "clearing all codes" several times. Any ideas or suggestions would be greatly appreciated! 03 Cummins |
Your pad wear sensor circuit is "open" somewhere. Based on what you say above, I would suspect one of the sensor-to-chassis-harness connectors is not seated properly or is damaged somehow.
Or one of your pad wear sensors is defective. The sensor should show continuity at the connector end of the sensor wire harness.
Congratulations on your search skills. You found a five+ year old thread!!
