Just finished brake fluid swap
Results 1 to 9 of 9
Suspension, Brakes and Tires Discussion, Just finished brake fluid swap in Item Specific Cadillac Discussion; What a difference it makes! The pedal feel is much different. THe old fluid was darker than coca-cola. I followed ...
    Matthew is offline Cadillac Owners Fanatic
    Feb 2004
    137
    I followed the directions on joe vetos website, it is so simple and CHEAP to do.
    http://temp.corvetteforum.net/c3/joe..._Bleeder.shtml that is Joes website.
    THanks alot Joe, its appreicated.
    Matt
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: Just finished brake fluid swap
    The fluid had to have really bad.....
    Looked at that website, and looks like a good procedure.. Speed vacuum bleeders make life so much easier...
    joeveto's Avatar
    joeveto is offline Cadillac Owners Member
    Feb 2004
    Cuyahoga Falls, OH
    94
    Matthew, I'm glad it went well for you. A lot of people don't realize how bad or older fluid can have a negative effect on their braking performance.
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    Not to mention it is hell on all your brake parts espeically ABS actuator!!!
    Do the cheap stuff ($20 in fluid/bleeders) to save buying the expensive stuff ($500+ for the ABS unit)
    cadillac6's Avatar
    cadillac6 is offline Cadillac Owners Fanatic
    Oct 2003
    NC
    34
    149
    I would like to try this in my 97 concours but have no idea on how to do I looked at the site but am still confused. What color should the brake fluid be?
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    Brake fluid should be pretty much clear... Maybe a slight yellow hue...
    Feb 2004
    137
    Quote Originally Posted by cadillac6
    the fluid should be clear, mine was very dark like coke. very easy to do. I bought a big bottle of brake fluid for $4.75 and 87 cents of clear hose.
    just follow the directions of the website and youll be ok. Just be careful so you dont bust off a bleeder. My rear bleeders were alittle tough to crack open so I soaked them with wd40.
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    I still recommend using a speed bleeder... Harbor frieght has them for like $30.. All you do is open the bleeder and pump.. The hardest part is taking off the wheels...
    joeveto's Avatar
    Feb 2004
    Cuyahoga Falls, OH
    94
    Quote Originally Posted by elwesso
    I was just at Harbor Freight, today. I wish I knew they had them. I'd love to try them.
  12. Remove Advertisements
