plastic line from strut to compressor in broken
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, plastic line from strut to compressor in broken in Item Specific Cadillac Discussion; I was in the process of looking at my rear brakes when I noticed a little black plastic line hanging ...
    Matthew is offline Cadillac Owners Fanatic
    Feb 2004
    137
    I was in the process of looking at my rear brakes when I noticed a little black plastic line hanging from my rear passenger strut. I climbed underneath to and found the other part of it.
    My compressor doesnt run that often, i only notice it like once a week at the very most. Does caddy sell the lines? It looks like it a one piece connector that has a line that goes to both sides.
    Would it be worth replacing the line when my car is 10 yrs old and has 130000 miles on it?
    I know the front struts are in need of replacing and I will put some passive KYB's on there, just wondering if its even worth-while to replace the line.
    Also, I gots a question about doing the rear brakes in my car. DO you just take off one bolt so the calipers pivot up or what? Ive never seen a setup like this one before.
    Thanks, Matt
    Feb 2004
    137
    Re: plastic line from strut to compressor in broken
    Its a 94 Sedan Deville
    Cadillac-Junkie's Avatar
    Cadillac-Junkie is offline Cadillac Owners Member
    Mar 2004
    EVERETT MASS
    50
    82
    yes u can replace it and if it works it the cheapest way too or go to bostonsuspensio.com they sell back air shocks they will do the job forthe back and fronts if u need them but i like thre air shocks myself for the back
