I was flipping through the Power Slot brake catalog today and noticed that 98 to 04 Seville front brake rotors are the same as 98-03 Camaro/Firebird front rotors. Baer Brakes makes a killer slotted/drilled/zinc-washed Eradispeed front rotor for the 98-03 Camaro and I thought it would look awesome on the Caddy if it will fit. I called them today and was told it will fit the stock 17" rims on the Camaro so it should work on the 17" STS rims as well.
I could not get a definate YES if it will work on the Caddy, so has anyone here done this swap? Any info would be helpful.
