Results 16 to 22 of 22
Thread: Swapping Northstar for LS Engine
    Villanous's Avatar
    Villanous is offline Cadillac Owners Member
    Automobile(s): 96 Eldorado base model 4.6Northstar
    Aug 2008
    Boston
    53
    Re: Swapping Northstar for LS Engine
    Not sure if this helps any but this is a link to a guy who swapped out a 6cyl in an impala for the LS4. Few good pics about some of the changes he had to do.
    http://www.cardomain.com/ride/2390354
    Cool.
    Maybe when I can get Sandy to give me his 60 I can do a 5.3L swap in it and never pop the hood...
    Thanks! I think this is one of the best swaps for the 85-94 FWD Deville/Fleetwood/60 Special.
    But it also makes a lower cost alternative to rebuilding a blown gasket Northstar with a LS4.
    Cliff8928 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Jul 2008
    Long Grove, IL
    416
    Quote Originally Posted by benelliwang View Post
    Not so, the difference is the bore:
    3.779" x 3.622 (LS4) vs. 4.000" x 3.622 (LQ4)
    The LS4 bore is smaller then LS1 (5.7), LS2 (6.0), LS3 (6.2), & LS7 (7.0). Other then the LS7, they share the same stroke but different bores.
    The LY2 (4.8) is the one with the shorter stroke just to clear that up...
    fierodough is offline Cadillac Owners Fanatic
    Automobile(s): 06 Escalade
    Sep 2008
    Canada
    39
    282
    Why would you want to get rid of your N*? the N* engine came from a 2 peaice racing block. For less then what it would cost to drop in an SBC or LS, you can be tapping into much much more power with the N* engine.
    I would recomend doing a search on PCM tuning and cam swap. There is a video on the net somewhere of a N* with swapped cams holding 14K RPM for several hours without any faillures.
    Keep in mind that the N* was delibratly tammed down for the Caddilac platform doue to Cadillac's targetted customer base. (Ritered elderly people looking for luxury).
    I'll see what i can digg up and post it here.
    Reliability, power and mods are dirt cheap on a LS4 than a NorthStar....
    Simple economics....
    Imagine a 85 FWD Deville with a LS4 in it. SLEEPER.....
    Enano is offline Cadillac Owners Member
    Automobile(s): 99 Deville
    22
    Quote Originally Posted by fierodough View Post
    ever find this video? your sayin a stock N* holding 14k rpms?
    someon said the ls3 is a near bolt in. what kind of welding needs to be done. are we just talking brackets to mount the engine?
    LS4, lots of go fast parts, can make stupid amounts of power easily.
    NorthStar, no go fast parts, hard pressed no matter what you do normally aspirated to make over 325 hp.
    LS4 hp/$ is low
    NorthStar hp/$ is high
