Results 16 to 30 of 39
Thread: Northstar Water Pump Replacment Steps
    Indiana
    873
    Re: Northstar Water Pump Replacment Steps
    Thanks got it out and water pump back in. Trying to figure this tensioner out now.
    Indiana
    873
    Quote Originally Posted by 99esteees View Post
    Got it all back together and ready to go, pending the new upper hose and coolant in the morning. Wish me the best.
    Drparj is offline Cadillac Owners Member
    Automobile(s): 99 Cadillac Seville SLS
    New Hampshire
    64
    Ok I just got done doing a full flush on the coolant and then got it all back together. I actually used one of those $10 flush kits you can get anywhere. They work great and hurt nothing, but they do allow the system to clean out most everything. I remove the thermostat and put back together without one. I then open rediator drain and turn hose on to back flush coupler and then discconnect upper hose and turn motor on. Old fluid will flow out top hose and you run about for 10 minutes and you will see nice clear fluid after that. Then I take coupler off and let motor run for about 30 20 seconds to help push leftover water through motor. Then put everything back together and add bars leak golden seal and dex cool 50/50 and presto nice clean system and no problems ever.
    Indiana
    873
    I went to pour the coolant in this morning and it all leaked back out. I put in 2 quarts. It feels to be coming from the water pump area, but I don't know what could have gone wrong? I put in a new cover gasket and a new o ring. It's worse than it was before.
    New Hampshire
    64
    Did you make sure to use a torque wrench to tighten everything back up to specs and tighten back and forth evenly on the bolts. Does it look to be coming from gasket area or hose area? Worst case if nothing works try a little bit of liquid gasket to help the water pump gasket make a better seal
    Indiana
    873
    Pretty sure it's coming from the crossover area near the block. I can't get to a few bolts, so I guess i'm putting it back together and calling the dealer to get a price quote in the morning. Ughh
    New Hampshire
    64
    take it apart look to see if the gasket is messed up and try some liquid gasket on the oem gasket and reinstall. Liquid gasket usually will fill the irregularities. Dealer will charge you $100-$200 most likely to fix with no parts, but sure its something simple.
    STSJim is offline Cadillac Owners Member
    Automobile(s): 1996 STS
    16
    Big thanks to the OP and everyone else that chimed in! I was able to do this repair in my driveway and saved about $400!!! Anyone considering a DIY water pump replacement... go for it!
    Thanks for the instructions. One thing I'll ad is to use an impact wrench on the removal tool.
    My water pump was being very stubborn, I had a 3 foot pipe on my removal tool and it wouldn't budge, plus after cranking on it my removal tool started to clip cock-eyed.
    Then I got out my chisel and started to hammer the one tab I could get to, that just mashed the metal, I thought I was really in trouble.
    As a last resort I got out my impact wrench. With my full weight pushing the impact wrench tight against the housing (straight) and on max torque, it took about 20 seconds of impacting to get it off... which is about an eternity in impact-wrench land.
    My suggestion, try the breaker bar first, but if that doesn't work go right to the impact wrench. It didn't damage the tool, and it probably would have come off easier if I hadn't buggered the one tab with my chisel. If I ever have to do one of these again I'm going right to impact.
    DBC's Avatar
    DBC is offline Cadillac Owners Member
    Automobile(s): 1994 SLS
    53
    Actually I just was working on my water pump on a 94 4.6 engine. My pump was installed so tightly and or corroded in there that one or two of the slots on the pump started wearing off so the removal tool tabs were just sliding off! I finally got my impact wrench in there and the hammering action of the wrench was enough to carefully pop the tangs of the pump out from under the retaining tabs of the housing. That was really annoying.
    DBC's Avatar
    53
    Also, is there really an orientation for the one tang on the pump that does not look like the others? I just noticed that it looks like a coolant pass through hole is on the pump housing and if you put the unusual tang at the 7:00 O'clock orientation that the manual says to then that pass through hole is straight up and down. Which would seem to make sure that gravitationally the cooling fluid would run through that hole better.
    Well my real question is how do you know that you have the unit seated all the way?
    samm is offline Cadillac Owners Fanatic
    Automobile(s): 2002 STS
    Sep 2004
    SE Minn.
    370
    I am wondering the orientation of the water pump as well. It came out with a small (12") ratchet easy enough, a few taps on the ratchet got it out. However, I cannot get it back in - even with a 24" breaker. I don't want to take an impact to it until I know its in the correct orientation. I will try tab w/o mini tab in 7:00 position and report back.
    82,278
    DO NOT use an impact to install it.
    2002 Devile DTS is offline Cadillac Owners Member
    Automobile(s): 2002 DTS
    8
    Has anyone came up with an answer to the orientation of the water pump tabs for installation?
    Brian
    82,278
    Just take note of the tab positions of the old one you remove.
