Page 6 of 6 FirstFirst 123456
Results 76 to 83 of 83
Thread: Northstar Oil Usage
  1. #76
    56,849
    Re: Northstar Oil Usage
    Quote Originally Posted by tateos View Post
    The car is nice...but I still say I LOVE the front yard Sub!
    Tks..........Just beyond the big dark oak and pine tree cluster over the car hood we have a 100 yard rifle range that goes down the clearing to the right. The range shoots south down our private gravel road - the nearest home is another 150 yards down the road, off to the right. We all shoot rifle and pistol here and we all (6 of us) maintain the range and road.
  2. #77
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Wyoming
    5,748
    O.k. gotta get my 2 cents in on this one, althought the thread is old. Got me a 96 Deville VIN Y in October of 2008 from Cadillac of Sioux Falls (SD). Had 38,947, now she's got a tick over 65. Always kept the oil within range (at the "halfway" mark), and I do change it nearly on the dot at 3,000. I'm a 21 year old with a lead foot, so the WOTs are no issue. Doesn't burn a drop of oil, doesn't leak, and she runs like a top (save the aging plugs). The 4.9 is a decent motor, and it's a whole different ball game compard to the N*, but it just doesn't offer the performance, economy, and enjoyment that the ol' N* does. Is the N* flawed? Probably not. IMHO, it's more of a negligence issue on the part of the less-than-enthusiastic owners out there. Sure, it's not the hottest thing out there, but it will shame 95% of the stuff out there. Besides, who says you can't tune the PCM or engineer some new direct injection heads?
  3. #78
    56,849
    Trouble with DI heads on a Northstar is the central spark plug location surrounded by 4 valves - and up top, cams and valve springs/retainers around the plug well.
    Talk to AJ or Lynden Wester about tweaking the PCM on that early OBD-II engine.
  4. #79
    Wyoming
    5,748
    Darn it, I forgot about that I will be doing the PCM tuning though.
  5. #80
    56,849
    DO NOT expect any miracles - or even close - on a VIN Y drivetrain tune. The single best "performance" mod - and it will get you maybe 2 - 3 hp - is a custom bent cat-back exhaust system. $$$$.$$
  6. #81
    Mark D is offline Cadillac Owners Member
    Automobile(s): 1995 Seville STS 1998 Seville STS 1995 Seville SLS 2000 ET
    Nov 2011
    I came into this thread late, and have not taken the time (because I don't have that much time) to read all the posts.
    But I have read the first few and some others.
    I thought I'd add this insight, or maybe I should call it my own experience with oil consumption.
    First, I have a '95 VIN9 in a STS that has 227K miles on it. It uses about a half quart of oil between changes at around 4000 miles.
    Second, I have a '98 VIN9 in a STS that has 200 K miles on it. It's the car I just did head gaskets on.
    We (wife and I) got that car with about 95K miles on it back in 2002. It burned about a quart of oil in 800 to 900 miles.
    But as time has gone on, the consumption continued to drop to the point where it now burns about a quart in 2500 or so miles. To me, a guy who's used to cars from the '60s and 70's where typical consumption was a quart in 1000 miles, or less, this is just fine.
    At least it has gotten better, not worse.
    Is adding a quart of oil every few weeks that big of a deal? At least knowing you need to check the oil will get one to open the hood and look around for any unknown maintenance issues that might be coming up, like antifreeze leaking, worn belts, etc. A contientious car owner will check things under the hood at least every week or so, won't he? Perfect time to check the oil and add if needed.
    It'll burn less if you don't top it right to the top of the dip stick markings.
    Mark D.
  7. #82
    tincansailor is offline Cadillac Owners Member
    Automobile(s): 08' DTS
    Jan 2017
    Arkansas
    76
    I had an independent mechanic tell me he hated the Northstar engine then my wife went out and bought a used DTS with one in it. At the time it had 40K so I changed oil using Amsoil Signature 5-30 and the 25K filter because I'm getting old and changing oil isn't as much fun any more. We're now at 68K and I add a quart every 4K. No big deal since I always felt that no oil consumption meant inadequate lubrication. The comment about "it has 32 valves for god's sake" made me smile.
  8. #83
    56,849
    Your late model DTS/Northstar is atypical of the earlier models predominantly discussed in here.
    The thread has been dead for 5 years. You might want to reset your profile thread/post view preferences to "View latest threads/posts first". That way you avoid rehashing past history.
    AMSOIL makes some right decent lubricants - but the extra price of admission isn't needed for long, efficient daily driver engine life. I use Pennzoil Platinum 5W-30 and a WIX 51522 filter and get over 6,500 miles to the quart. The car is a garage queen now, gets driven less than that 6,500 miles a year, so I change oil/filter each spring, mileage be damned. The car DOES get driven "in spirited fashion" when Karen and I go over to Caroline County for some twisties and an airport (abandoned farm road/runway) speed run or two. Yes, I keep oil level in the lower half of the dipstick hashmark. Any higher is overfilled.
    Read this link, especially the bottom of P.2 and first part of P.3. in Post #1 - http://www.cadillacforums.com/forums...roper-oil.html
    Nonetheless, there's still some good info for early Northstar owners in here...............and it's always fun to restart yet another oil war.
